Home » Audio » Speaker » Altec 902 / Edgarhorns: compensation experiments
Re: Series and Shunt Resistance [message #17689 is a reply to message #17686] Mon, 28 March 2005 20:41 Go to previous message
Glad that helped, Floyd. Do plug the numbers into Spice or measure the system, whichever is best for you. That will make sure you've chosen values that give you good clean response. Depending on the reactive values surrounding the circuit, you may want the shunt resistance after the series resistance instead of before it. It will also help you select the values that work best.
Previous Topic: PHY-HP - Know anything about these?
Next Topic: Does anybody here know how to add and subtract?
Current Time: Wed Nov 04 08:06:05 CST 2026
