Home » Audio » Speaker » Discontinuity in horn : is it important ?
Re: Discontinuity in horn : is it important ? [message #17670 is a reply to message #17669] Wed, 23 March 2005 20:47 Go to previous messageGo to previous message
There is a terminus at both ends of all horns. An infinite horn is a theoretical thing. You can radius the edge to meet the baffle if you like, and you can match the entry of the horn to the built-in flare of the compression driver. Sometimes this makes a big difference, sometimes not. Best to model the horn and see, or measure a physical model if you have one available.
Previous Topic: Large Heils & Hi-Vi M8A's
Next Topic: Repeated JVC Question
Current Time: Tue Nov 03 23:43:48 CST 2026
