Home » Audio » Speaker » Measuring sensitivity
Re: going way out on a limb here... [message #17635 is a reply to message #17630] Mon, 07 March 2005 05:57 Go to previous messageGo to previous message
JLapaire is currently offline  JLapaire
Let's see if I've got this right: TruRTA has a sine generator, which I'd set to 1kHz, adjust level for 2.83vac (assuming 8 ohm) across the speaker terminals, then read dB spl at same settings with pink noise?
I tried something like that before, at 60hz, and noticed that if I read 108db with sine, pink noise would be maybe 100 or less. I think I was seeing what you said I should see.
What I'm trying to do is be able to answer honestly when someone asks what the sensitivity of my speakers is. In the above case, would it be 108 or 100?
Thanks,
John
Previous Topic: SET Friendly Arrays???
Next Topic: Volume dropping/bsc filtering
Current Time: Mon Nov 02 09:37:34 CST 2026
