Home » Audio » Speaker » Measuring sensitivity
Re: going way out on a limb here... [message #17629 is a reply to message #17628] Thu, 03 March 2005 19:03 Go to previous messageGo to previous message
footstony is currently offline  footstony
Some DVM's have trouble with AC volts at higher frequencies. Some don't go over 1kHz, others may go over 1Mhz. Most will work well and are calibrated at lower frequencies around 50 or 60Hz in line with mains supply frequencies.
You will need to check the spec.s for the meter.
There may be an issue with how the meter derives the rms value. Some use "true rms" others use averaging which will not work for pink noise.
Regards Philip
Previous Topic: SET Friendly Arrays???
Next Topic: Volume dropping/bsc filtering
Current Time: Mon Nov 02 09:38:26 CST 2026
