Home » Audio » Speaker » Is Neo really the One? Oracle Cleo wouldn't tell me...
Re: Thanks, Earl! [message #17529 is a reply to message #17528] Mon, 31 January 2005 06:38 Go to previous messageGo to previous message
Wayne
Correct, anything that helps cool the voice coil helps the situation. I was mostly refering to the fact that it is the wire heating that accounts for most of the compression.
Vents help a lot esspecially when high power is an issue. But as Duke points out, heat in a home system (using pro speakers) is not really an issue. Few people realize however, how much difference there is in the effect of heating between a smaller wide band driver (like the typical 6 1/2 inch woofer) and a large band limited pro driver. Under normal conditions heating of the pro driver is not an issue,but it is a big issue in the small driver even at normal listening levels.
There is a very good paper on driver heating in the JAES some months back. If I find it, I'll let you know.
Previous Topic: Fostex f120a
Next Topic: Measurements
Current Time: Sat Oct 31 23:54:21 CDT 2026
