Home » Audio » Speaker » Is Neo really the One? Oracle Cleo wouldn't tell me...
Re: Thanks, Earl! [message #17528 is a reply to message #17527] Mon, 31 January 2005 05:11 Go to previous messageGo to previous message
Do you think that cooling vents are worthwhile for removing heat from voice coils? Do you have any data that quantifies the thermal performance, perhaps a comparison of vented and unvented speakers?
I think that you're probably right that the voice coil heats pretty quickly after power is applied. But I also think that anything that removes heat will help. I imagine that the whole idea of venting was to carry some of the heat away, and as inefficient as it is, I expect it probably provides some benefit. I also imagine that if the pumping action of the vent were improved, the thermal performance would also be improved, compression reduced and power handling increased.
What say you?
Previous Topic: Fostex f120a
Next Topic: Measurements
Current Time: Sat Oct 31 23:54:20 CDT 2026
