Home » Audio » Speaker » System impedence
Re: Maybe I will change my order to 8 ohm diaphrams [message #17477 is a reply to message #17476] Mon, 24 January 2005 15:01 Go to previous message
If your amp is designed for an 8 ohm load, you might be better off using 8 ohm speakers. It isn't usually a problem if impedance rises, but power transfer might be reduced a little bit. Impedance at low frequencies is sometimes more of a problem.
Glad you're enjoying the speakers you won in the 25,000th post game. Colin Hester made the donation of the albums; I just agreed to substitute them for speakers if the winner had the albums or didn't have a turntable or whatever. So thanks go to Colin in this case.
By the way, what resistor are you refering to? Do you use a damping resistor or some sort of level matching?
Previous Topic: White Van
Next Topic: Is This Possible ?
Current Time: Sat Sep 19 19:05:25 CDT 2026
