Home » Audio » Speaker » System impedence
Re: System impedence [message #17467 is a reply to message #17459] Mon, 24 January 2005 08:10 Go to previous messageGo to previous message
adavis464 is currently offline  adavis464
Hi Wayne I'm aware of the power limitations and i'm sure the tweeter and midrange horns impedence are probably on the low side of 16 ohms(more like 10 to 12 in there operating band).Not only that I think they would run ok from 500hz on up with 10 watts.It the midbass at resonance that may be a problem but they only go down to 100hz.The low end will be my 2 18's stacked (parallel 103db1w1m).So i don't think Iwill have a bass problem.but from the amp stand point don't they operate more stabble at around 16 ohm? Regards Tim
Previous Topic: White Van
Next Topic: Is This Possible ?
Current Time: Fri Oct 16 23:46:28 CDT 2026
