Home » Audio » Speaker » Hi-Efficiency vs Lo-Efficiency Speakers
Re: Hi-Efficiency vs Lo-Efficiency Speakers [message #17318 is a reply to message #17309] Sun, 09 January 2005 03:20 Go to previous messageGo to previous message
Hi Earl,
I agree with you about directivity. I didn't mention it because while most high-efficiency speakers are (directional) horns, not all are.
About shorting rings, I'm not sure how they could reduce odd-order harmonics. I think that mechanical suspension movements and reduction of excursion reduce third-order though, so some of the better high-efficiency drivers probably have reduced third-order from improvements in that regard, in addition to reduced even-order distorton from the use of flux control rings.
Wayne
Previous Topic: fostex rear loaded horn design
Next Topic: Coral Beta 6 in Ebay
Current Time: Fri Nov 06 01:37:13 CST 2026
