Home » Audio » Speaker » Last question, I promise! (I'm lying)
Re: Last question, I promise! (I'm lying) [message #17298 is a reply to message #17297] Mon, 03 January 2005 22:12 Go to previous messageGo to previous message
GM is currently offline  GM
?? Altec bolted these to the 511B crossed at 500-800Hz/2nd order or to the 811B for 800-1200Hz/2nd order, no adapters required. WRT using adapters, unless the joints are seamless they add another discontinuity to cause HF reflections back to the throat, so unless you have a specific lens you need for your app I recommend using the ones they were designed for and damp them to suit (at least the bells).
GM
Previous Topic: Open baffle Focussed Line Arrays
Next Topic: Do more sensitive drivers offer less distortion at "normal" listening levels?
Current Time: Sat Nov 28 22:35:06 CST 2026
