Home » Audio » Speaker » Do more sensitive drivers offer less distortion at "normal" listening levels?
Re: Another perspective [message #17290 is a reply to message #17289] Sun, 02 January 2005 22:50 Go to previous messageGo to previous message
There are several things that I think make corner placement attractive, but one of the most obvious is that every room has them. With the typical 8 foot ceiling height, I figure on corner boundaries being effective from about 35Hz up.
I can't see any reason why the Schroeder frequency would be any sort of upper limit for directivity control. If anything, it's the very low frequencies where even the relatively large dimensions of the walls would become too small for pattern control.
It's a mute point though I suppose because most voice-range systems aren't corner loaded, as they are too far from the corner apex. It's the bass system, up to about 200Hz, that I'm referring to when I speak of corner loading.
Previous Topic: Last question, I promise! (I'm lying)
Next Topic: Geddes Waveguide
Current Time: Sat Nov 28 22:25:04 CST 2026
