Home » Audio » Speaker » Do more sensitive drivers offer less distortion at "normal" listening levels?
Re: Another perspective [message #17275 is a reply to message #17272] Sat, 25 December 2004 08:10 Go to previous messageGo to previous message
Hi Earl,
There's one way to get 90o directivity from a single LF source, and that's to put it into a corner. Other than that, a free-standing basshorn can't because it isn't large enough. Room corners can provide 90o directivity because the walls are large enough to direct the wavefront.
About distortion, I can always hear the difference between a driver with an effective shorting ring and I think you're right about the reason why. Even-order harmonics are suppressed well up into the midrange. Flux control rings aren't usually made big enough to do a particularly good job at very low bass frequencies, but they work great from midbass through the midrange. The power range I'm talking about is from about 1% to maybe 25% or so, maybe as high as 50%. For a 600 watt driver, between 10 watts and 100 watts, the difference between one with an effective shorting ring and another similar unit without a ring is clearly audible.
Merry Christmas!
Wayne
Previous Topic: Last question, I promise! (I'm lying)
Next Topic: Geddes Waveguide
Current Time: Sat Nov 28 22:25:25 CST 2026
