Home » Audio » Speaker » help me with my Christmas list
Martinelli horns [message #17208 is a reply to message #17207] Thu, 18 November 2004 23:44 Go to previous messageGo to previous message
What frequency range and coverage pattern do you need? Will they be for home use I assume?
If you need horns in the $100.00 range, there are tons of good plastic horns so it becomes a matter of dispersion pattern and intended use.
If you're considering TAD horns, you might check with Bill Martinelli at www.WoodHorn.com. He's a sponsor of AudioRoundTable.com. Martinelli makes fine wood horns and I like them a lot. They aren't cheap though.
Previous Topic: Enclosure for Fostex 167E
Next Topic: Cool single driver speakers from Japan
Current Time: Sun Nov 29 00:19:18 CST 2026
