Home » Audio » Speaker » Bandpass subs
Re: I'm using one... [message #17206 is a reply to message #17205] Wed, 17 November 2004 02:53 Go to previous messageGo to previous message
You're right. I'd PREFER a closed box, or, ideally, a horn - but a horn that works down to 28Hz? Jeez... It would fill my room!
What I like about my BP is, that it doesn't exagerate - I've heard way too many subs, that were very busy telling the whole world they were here. My sub delivers when it's supposed to. I think it's 'Q' is about similar to a closed box with Q=1 - not great, but not bad, either. An interesting point is, that my sub isn't exactly small, in hifi terms at least. Btw., the roll-off of my sub IS 12dB/octave a bit down - the initial is probably close to 15dB/oct.
What people often don't consider is the influence of the room. It's close to impossible to judge a sub if one don't take that into consideration - the 'Q' from various room modes can make a sub sound quite different, for better or worse, than it's specs will tell you.
Previous Topic: Light Show from Speaker Port
Next Topic: Technics 20PW-49S Coaxial Drivers
Current Time: Fri Nov 13 10:47:56 CST 2026
