Home » Audio » Speaker » 100-600Hz
Re: 100-600Hz [message #17057 is a reply to message #17047] Wed, 06 October 2004 17:55 Go to previous message
Hi Klaus,
My vote is that you check into building one. I think you will have little trouble covering the 100-600 range and can probably do it nicely with an easy-to-build horn having straight side walls for its flare.
Where will these be installed? As has been mentioned, that's very important and goes to the point of how large the horn must be. If it will be used indoors, and particularly if used in corners, the horn can be considerably smaller than if it will be used in freespace.
Wayne
Previous Topic: JBL 2380 clones?
Next Topic: Low BL drivers exhibiting higher power compression
Current Time: Thu Nov 05 02:59:27 CST 2026
