Home » Audio » Speaker » Horn length (revisited)
Re: Horn length (revisited) [message #17052 is a reply to message #17016] Wed, 06 October 2004 09:33 Go to previous message
Oberon is currently offline  Oberon
Horns *can* be made smaller in some situations, and use in groups is one of them. Venue is very important, as the correct size can vary as much as 10X depending on usage.
There is a common misunderstanding that horns must be 1/4 wave long and mouth area must be 1/4 wavelength in circumference. This is only a rule of thumb. If a horn is flown alone, that's true, and length should really be 1/2 wave. However, that is rarely the case and almost never for basshorns.
Basshorns are almost always used on the ground, which cuts these values in half. Use a pair of basshorns on the ground and the size is cut by 1/4. In fact, the most common basshorn is actually 1/8th size. It is smaller both in length and in area. If used in groups, 1/8 size horn is all you need. This will be both shorter in path length and smaller in mouth size than 1/4 wave.
Previous Topic: Eminence chrome label
Next Topic: JBL 2380 clones?
Current Time: Thu Nov 05 06:15:18 CST 2026
