Home » Audio » Speaker » Low BL drivers exhibiting higher power compression
Re: Low BL drivers exhibiting higher power compression [message #17051 is a reply to message #17049] Wed, 06 October 2004 06:40 Go to previous messageGo to previous message
It's a matter of the acoustical impedance of the horn. If it is high enough and you try push the driver to long enough excursion there will come a point where the motor strength is insufficient to overcome the impedance offered by the air column mass and the cone motion versus input voltage is no longer linear.
Can't help on the math- flunked it.
Previous Topic: 100-600Hz
Next Topic: Outer dims of Autotuba
Current Time: Wed Nov 04 19:31:59 CST 2026
