Home » Audio » Speaker » 100-600Hz
100-600Hz [message #17047] Wed, 06 October 2004 03:53 Go to previous message
Klaus is currently offline  Klaus
Thanks Bill and Julenk for the reply on the Yamaha Horn question.
I really need a good sounding horn from 100 - 600hz.
I have a WO from Steeve Deckert for the sub.
This rubber throat horn has two 10" and sounds really powerfull and clean in the low region from 35-150hz, but i miss a loud enough low-mid.
Anyway I need a horn that will cover the region mentioned above.
I would like to use a 8" high Fs light cone speaker in a straight horn design but that seems to get to big.
Do any of you have an idea what to build in this case.
I would like to keep it under 24" wide.
Klaus
Previous Topic: JBL 2380 clones?
Next Topic: Low BL drivers exhibiting higher power compression
Current Time: Thu Nov 05 18:15:13 CST 2026
