Home » Audio » Speaker » Horn length (revisited)
Re: Horn Mouths [message #17021 is a reply to message #17019] Mon, 04 October 2004 06:45 Go to previous messageGo to previous message
'Theres no way to make a basshorn small'
Depends what you call small. Using room reinforcement (and if your speaker is in a room why aren't you?) you can get down to the 3.5-4 cubic foot range with useable response to 25Hz no problem. You do have to keep the pathway long, which means a small mouth, and you have to toss the 'old school' reliance on hypex tapers. When 'going by the book' doesn't work sometimes you just have to write a new book.
Previous Topic: Eminence chrome label
Next Topic: JBL 2380 clones?
Current Time: Thu Nov 05 07:29:12 CST 2026
