Home » Audio » Speaker » Opinions needed: Aluminum or Pascalite?
Re: Opinions needed: Aluminum or Pascalite? [message #17007 is a reply to message #17006] Sun, 26 September 2004 15:22 Go to previous messageGo to previous message
First you are correct, the magnet is visibly smaller. If you look into the driver there is a tangerine colored plastic ring visible. I have not yet taken them apart so I can't answer the rest of your question about the loading caps. I will most certainly check on that and report back. Thanks J.R.
Previous Topic: fostex and speaker cables
Next Topic: near field chaos
Current Time: Sat Oct 24 14:01:40 CDT 2026
