Home » Audio » Speaker » Horn gain - directed sound or acoustic transformer?
Re: Both! [message #16989 is a reply to message #16988] Fri, 17 September 2004 18:17 Go to previous messageGo to previous message
Oberon is currently offline  Oberon
"the horn still can easily exhibit 10dB or more of gain over the direct radiator using the same driver."
A direct radiator in 1/8th space exhibits 9dB gain over the same radiator in open space so the directional aspect is significant.
Just an observation. This is not to say the impedance matching aspect is not also significant for its own reasons.
Previous Topic: Tapered pipes to horns
Next Topic: Re: Decware Single Driver Fostex F206 Transmission line
Current Time: Fri Oct 16 02:56:49 CDT 2026
