Home » Audio » Speaker » Tapered pipes to horns
Re: Tapered pipes to horns [message #16987 is a reply to message #16984] Fri, 17 September 2004 07:55 Go to previous message
The answer is simple: put the opening on the small end and you have a TQWP. Put it on the large end and you have a conic taper horn. The TQWP has gain only in the octave or so above Fp, and that is attributable to its quarter-wave configuration. It has numerous ripples above the Fp, which must be damped out with stuffing. Ideally the pipe output of the TQWP is low frequency only, the higher frequencies eliminated by the damping.
The horn has broadband gain, from both quarter-wave and acoustic impedance matching, and while not ripple free it's far less susceptible than a TQWP; you don't damp a horn as that would kill the higher frequencies passing through it, assuming it's a front loaded design. Rear loaded horns usually are folded, and that often serves as a sufficient low-pass filter.
Previous Topic: Ping Martin King
Next Topic: Horn gain - directed sound or acoustic transformer?
Current Time: Fri Nov 06 01:48:14 CST 2026
