Home » Audio » Speaker » Truncated horns
Exactly [message #16924 is a reply to message #16923] Thu, 02 September 2004 06:11 Go to previous messageGo to previous message
Couldn't have said it better myself. But what also should be noted is that horns can make very efficient use of drivers, and therefore are quite cost effective. If you make a horn so small that you need a whole bunch of them to work right, and thus a whole bunch of drivers as well, then you're losing out on one of the main benefits of having horns to begin with. You're better off just finding a self-standing design that is of a size that you can deal with.
Previous Topic: Tang Band drivers
Next Topic: Line array question using Bandor 50mm driver?
Current Time: Thu Nov 26 09:41:43 CST 2026
