Home » Audio » Speaker » Electro Voice EV15L
Re: "does not add significant broadband gain" [message #16874 is a reply to message #16871] Sun, 22 August 2004 15:42 Go to previous messageGo to previous message
Because the lowering of the Fb by the front chamber allows the driver to operate to a lower frequency than otherwise. In effect you do get gain in the low end over a single-chamber reflex, but the amount of gain is slight (3-5dB or so) and only extends over perhaps a half-octave range at best, compared to a horn where gain of 10-15dB over a two octave or better bandwidth is de rigeur.
Previous Topic: Speaker efficiency?
Next Topic: Line array driven as a phased array to create directionality?
Current Time: Thu Nov 05 01:59:08 CST 2026
