Home » Audio » Speaker » Horn throat size
Re: Horn throat size [message #16856 is a reply to message #16854] Sat, 21 August 2004 01:15 Go to previous messageGo to previous message
Compression ratio is regarded as being safe at 2:1 but after 3:1 problems can easily occur with loudspeaker cones.
The mcbean program will show you responses but wont tell you if distortion will result from your miniature too small horn throat
But with a little knowledge applied to the program,meaningful results happen.
http://www.volvotreter.de/ >downloads > dinsdale horn article
http://www.volvotreter.de/downloads/Dinsdale_Horns_1.pdf
Previous Topic: Thinking inside the box
Next Topic: 25Hz monster horn
Current Time: Thu Nov 12 09:01:16 CST 2026
