Home » Audio » Speaker » Horn throat size
Horn throat size [message #16854] Fri, 20 August 2004 16:36 Go to previous message
Ralph is currently offline  Ralph
If reducing throat size increases compression ratio, efficiency and overall horn size, why not make the throat as small as possible? I can understand that there would be some point where the throat would be so small it would set up a sort of squeeze effect and might make turbulence noises too. There should be a best size though, and it seems like that would be small. Is there an advantage to making the throat larger?
Previous Topic: Thinking inside the box
Next Topic: 25Hz monster horn
Current Time: Thu Nov 12 09:01:17 CST 2026
