Home » Audio » Speaker » Horns / Arrays
Re: Horns / Arrays [message #16848 is a reply to message #16847] Fri, 20 August 2004 08:03 Go to previous messageGo to previous message
I assume by arrays you mean a line array of direct radiators in a single box; keep in mind that a line array of horn loaded drivers is also possible. If you do mean a single box line array versus a single horn loaded box the line array will likely be a tall skinny box as opposed to a squat horn loaded box, and as such the line array will go to a lower frequency in the nearfield mode, while the shorter, wider horn will go to a lower frequency for the baffle step.
Previous Topic: Bill Fitzmaurice, How's your Line Array hybrid coming along?
Next Topic: Speaker efficiency?
Current Time: Wed Nov 04 10:04:34 CST 2026
