Home » Audio » Speaker » Bill Fitzmaurice Folding Geometry
Re: Bill Fitzmaurice Folding Geometry [message #16773 is a reply to message #16772] Thu, 05 August 2004 10:59 Go to previous messageGo to previous message
The high end will roll off when you don't use rounded bends. Since this is a sub and I wanted the high end to roll off so I left the bends squared. In my DR horns, which are full range, I use rounded bends and they're good up to at least 2kHz, basically needing to be crossed over when off-axis response starts to deteriorate.
My flare for subs has a much longer pathway to cross-section that the usual. This allows a far deeper extension and efficiency from a smaller package than is possible with standard flares.
By and large you can do just about anything folding wise up to about 200Hz, but much above that you have go to round bends.
Previous Topic: Bill have you ever had the chance to have a manufacturer costume build you a driver for your horns ?
Next Topic: pa drivers
Current Time: Wed Oct 21 04:23:39 CDT 2026
