Home » Audio » Speaker » If JBLPro Components are so great ...
Re: If JBLPro Components are so great ... [message #16701 is a reply to message #16695] Mon, 12 July 2004 18:35 Go to previous messageGo to previous message
I just listened to a JBL K2 the other week. For 30K it's pricy and worth it!
They are too expensive. Every dollar in materials cost the consumer 4 dollars by the time its in a box on a store shelf. Theres maybe a handfull of builders using expensive parts and the prices for the good reflect it. There are by the same token a few builders commanding huge dollars for systems that use little more than a 30 dollar driver.
The parts available from the Pro line is not as wide as it used to be. There are a lot of nice drivers by size and spec that were great for home audio, not made any more.
JBL also has a high end home theater line. I've not heard it but it looks like some classy stuff. high end. You find find it at Best Buy with the other JBL speakers.
Previous Topic: OB - V3
Next Topic: Martinelli FIRENZE
Current Time: Thu Nov 05 22:56:36 CST 2026
