Home » Audio » Speaker » A question about open-baffle dipole woofers
Re: dipole woofers and harmonics [message #16668 is a reply to message #16667] Thu, 08 July 2004 05:28 Go to previous messageGo to previous message
I see the biggest improvement from shorting rings above 100Hz, probably because they don't have to be as large to be effective. To get reduction in second harmonics down low requires a larger ring.
On the other hand, the use of complementary drivers as you've shown works best at low frequencies. At very low frequencies, coupling between drivers in a small chamber is high but as the frequency goes up, the distances involved cause a lack of coupling that reduces the effectiveness of this approach.
So I think that's why the push-pull configuration you've shown is found only in bass subsystems. You can use a shorting ring to good effect in midwoofers and midrange drivers. I'm hoping the B12 subwoofer is successful in reducing 2HD below 50Hz and that Eminence is able to provide a good high quality subwoofer with an effective shorting ring, but until someone does, the push-pull idea might be one of the best ways to reduce second-order harmonics at very low frequencies.
Previous Topic: Altec 515-8G
Next Topic: Anyone interested in reading a Selah Audio Omegarray review?
Current Time: Thu Nov 26 10:04:21 CST 2026
