Home » Audio » Speaker » 2nd order...what the doctor ordered?
so le5's ok ...806's???? [message #16605 is a reply to message #16604] Sat, 12 June 2004 09:25 Go to previous messageGo to previous message
gazzamongo is currently offline  gazzamongo
thanks for the replies
wayne.....the le5 on edgarmid horn should be ok then..
in the 1st order setup i'm using the 806/811 comes in a 5khz....so should be -24db by 312hz?....will it still breach its xmax with this slope...and at what kind of levels
i want to use this driver/horn combo as i can do without an actual tweeter (i think...or maybe a piezo coming in around 10k) and realise i couldn't junk the 806/811 and use say a jbl 2405 above the le5/edgarmid without going to a higher order crossover.
it's for home use so mega spls not req'd
will it fry.....what do you think
cheers
gary
Previous Topic: Help with 2235
Next Topic: The "magic" of single drivers: some thoughts
Current Time: Thu Nov 05 08:18:22 CST 2026
