Home » Audio » Speaker » 2nd order...what the doctor ordered?
2nd order...what the doctor ordered? [message #16602] Sat, 12 June 2004 06:42 Go to previous message
gazzamongo is currently offline  gazzamongo
i'm larking around with my new setup which is evm15l in karlson with le5 (in freespace) and 806/811
crossover is first order at 500hz and 5khs.sounds nice at low volumes but le5 is a little ragged at high volumes and 806/811 is also...but less so
for comparison i tried my behringer cx3400 and cheap nad amps (3130) crossing at various points between 800 hz and 1khz using karlson and 806/811 as a two.this sounded clean up as loud as i could bear...but lacked life and transparency (4th order!!!)
le5 will go in 300hz edgar midhorn soon , so will this keep it under control at high volume ?
do i need to go 2nd order, if so which one?
http://lalena.com/audio/calculator/apcxover/
....will it crush the life out of the sound?
should i forget about compression drivers ( or try 2" jbl /bigger altec?)
what crossover points/orders are people using with their compression drivers?
cheers
gary
p.s ( ruling out partisan advice...will not send 806/811 f.o.c to a good home...!)
Link: http://uk.f2.pg.photos.yahoo.com/ph/gazzamongo/slideshow2?.dir=/6982&.src=ph&.beg=1&.spd=2
Previous Topic: Help with 2235
Next Topic: The "magic" of single drivers: some thoughts
Current Time: Thu Nov 05 11:29:23 CST 2026
