Home » Audio » Speaker » How close can you sit to a frontloaded bass horn without compromise?
Re: How close can you sit to a frontloaded bass horn without compromise? [message #16595 is a reply to message #16569] Tue, 08 June 2004 09:18 Go to previous message
Mark Seaton is currently offline  Mark Seaton
Hi Guys,
Another factor people often overlook with large bass horns and speakers in general are where the dimensions place the source relative to boundaries. Many times someone will have a very deep box which places the mouth as much as 4' from the front wall. Well friends, the reflection from that boundary places a big null at 70Hz. Curious how so many say that they can't get that "punch" from big bass horns up close... Take that box and turn it 90 degrees and fire it along the wall or into the corner and most will change their tune.
Just something else to consider.
-Mark Seaton
Previous Topic: Buschhorn with visaton frs 8
Next Topic: TAD 2404
Current Time: Fri Sep 25 19:15:35 CDT 2026
