Home » Audio » Speaker » How close can you sit to a frontloaded bass horn without compromise?
Re: How close can you sit to a frontloaded bass horn without compromise? [message #16566 is a reply to message #16565] Mon, 31 May 2004 00:11 Go to previous messageGo to previous message
Peter Krojgaard is currently offline  Peter Krojgaard
Hi Bill,
Thanks a lot for your reply! Your answer implies some degress of freedom although I will probably settle on sitting outside the hornes:-).
Regards
Peter Krojgaard
Previous Topic: Buschhorn with visaton frs 8
Next Topic: TAD 2404
Current Time: Fri Nov 06 00:38:24 CST 2026
