Home » Audio » Speaker » How close can you sit to a frontloaded bass horn without compromise?
How close can you sit to a frontloaded bass horn without compromise? [message #16564] Sun, 30 May 2004 14:39 Go to previous message
Peter Krojgaard is currently offline  Peter Krojgaard
With the new bass horns I am planning to build, I will be sitting about 9 feet away from the mouth of the bass horns. Will this cause any compromises regarding lack of bass (or any other problems)due to the rather short distance to the horns? (FYI, I will sit much longer away from the mid horns, so this is not the issue:-)
I thank you a lot in anticipation and look forward to hear from you!
Regards
Peter Krojgaard
Previous Topic: Buschhorn with visaton frs 8
Next Topic: TAD 2404
Current Time: Fri Nov 06 00:37:59 CST 2026
