Home » Audio » Speaker » Playing with Mcbean
To elaborate further [message #16506 is a reply to message #16496] Mon, 17 May 2004 15:35 Go to previous message
I've found that parallel walls are of no consequence up to about 300 Hz or so but they will really foul up response above 500 Hz, so they're OK for basshorns but absolutely verboten for midrange or HF use.
Putting the mid horn in front of the basshorn is OK, as the low frequencies from the basshorn will find their way around obstacles. From a time align standpoint it is best to have the actual distance from the driver diaphraghms to the listening position the same, which usually would mean placing the mid horn in front of the basshorn would be a good thing, as long as it doesn't interfere with the room furnishings or exacerbate the WAF.
Previous Topic: midbass horn with 2226
Next Topic: CHoices! (basshorns)
Current Time: Fri Oct 23 08:19:43 CDT 2026
