Home » Audio » Speaker » Playing with Mcbean
Playing with Mcbean [message #16494] Sun, 16 May 2004 10:30 Go to previous message
adavis464 is currently offline  adavis464
What can I expect compared to the simulations if I make two side of the horn parrallel or even go one side with the flare.Also my room is 12by 14 I'm not planing to move soon can't I just build it into the room.I could start Both horns at one end and fire them to the frontAnd the mouth of both horns would be half the size of the front wall.Would it operate more like an infinit horn.If I set my main horn cluster in front of the sub horn will it effect it response much or at all.Lots of questions ? fun program when you learn to use it. regards tim
Previous Topic: midbass horn with 2226
Next Topic: CHoices! (basshorns)
Current Time: Fri Oct 23 08:19:00 CDT 2026
