Home » Audio » Speaker » Horn Cab for the Lab 12
Re: Horn Cab for the Lab 12 [message #16480 is a reply to message #16468] Sat, 15 May 2004 20:51 Go to previous messageGo to previous message
hi carl
I modeled up a 40hz horn for the lab12,for corner usage in a home.
No doubt,im sure it would be impressive. I have a 40hz horn already,and i like it alot,infact most the time (depending on program material) i cant tell if im using the 40hz horn or 33hz tuned jbl (ported) as i switched between them alot comparing.
Certain tunes will use that low end extension. I certainly would think a 40hz F3 is a valid target for most music especially in pro usage
Sizes were about 300-400Litres depending on if its a corner use horn or stack of 2 or 3 in 2pi space.
Although never built(due to $ cost)Everyone on the forums trusts mcbeans program to model an accurate response.
Cheers!
Mike.e
also
http://homepages.paradise.net.nz/quadroph/ts/ts.html
Btw my 40hz horn does 126db in the car with 20watts :-)
Previous Topic: Speaker Question
Next Topic: Audiophile Sub project
Current Time: Wed Nov 04 20:53:49 CST 2026
