Home » Audio » Speaker » Horn Cab for the Lab 12
Re: Horn Cab for the Lab 12 [message #16470 is a reply to message #16468] Fri, 14 May 2004 06:24 Go to previous messageGo to previous message
GraemeG is currently offline  GraemeG
Depending on your required usage, results may be dissapointing. As the Lab12 was specifically designed for the LabSub, I doubt any other variations will approach its performance. As far as folded horns go, the LabSub is quite simple, and any attempt to make the cabinet smaller will, out of neccessity, decrease path length and reduce mouth size - resulting in inferior low end response. If the application is home use, then corner loading plus the use of electronic equalisation (making use of the Lab12's excursion, with appropriate power requirements) may provide a usable combination.
Cheers
Previous Topic: Speaker Question
Next Topic: Audiophile Sub project
Current Time: Wed Nov 04 20:54:16 CST 2026
