Home » Audio » Speaker » Backhorns
Absolutely no. [message #16437 is a reply to message #16436] Fri, 07 May 2004 17:44 Go to previous messageGo to previous message
The rear-loaded horn has gain; a 'box' does not. Rear-loaded horns are usually combined with low Qts drivers that have nominal SPL ratings of 95-100dB/watt but little bass response without horn loading of the rear wave; the horn gain raises the bass response to the nominal SPL rating of the driver. 'Boxes' that use high Qts drivers don't need the additonal bass gain of a folded horn to have good bass response but on the other hand they also have typical sensitivities of 85-90dB. Therefore, on average rear-loaded folded horns will have sensitivity ratings 10dB higher than other cabinet styles.
By the way, efficiency is not the correct term when applied to how loud a speaker is for a given power input. This is generally stated as sensitivity, and usually stated as 'X'dB/1watt/1meter.
Previous Topic: BW of rear loaded horns
Next Topic: Stopped at the Bose store
Current Time: Thu Nov 05 22:16:56 CST 2026
