Home » Audio » Speaker » LC tuning instead of ports
Re: LC tuning instead of ports [message #16430 is a reply to message #16429] Thu, 06 May 2004 14:05 Go to previous messageGo to previous message
Also as you near Fb in a vented enclosure, or if your resonance circuits tuned a little above or below Fb, you can go over the execursion limits of the speaker. Especially when your using hi powered amps. That's one of the draw backs to it.
Wayne I don't know if you've heard of the ELF integrators that Bag End came out with several years ago, but it uses an integrator type circuit at the line level. It operates the speaker below Fb because the lower in freq. you go the higher the output, but they recommend that you use it in a sealed enclosure because with the system operating that far below Fb they use the air thats trapped in the enclosure. It acts a back spring for the speaker, so you don't send the cones flying across the room. You can use them with vented cabinets but they recommend you block the ports when using them.
Bill W.
Previous Topic: Lowther cabinets
Next Topic: Backhorns
Current Time: Fri Oct 23 09:26:48 CDT 2026
