Home » Audio » Speaker » seriers crossovers
Re: seriers crossovers [message #16414 is a reply to message #16413] Sat, 24 April 2004 12:27 Go to previous messageGo to previous message
Rod Elliot did an excellent article comparing series with parallel networks. I agree with his conclusion, that the most important thing is that the driver be included in any filter analysis. When so doing, you see the circuit less as a textbook filter and more as a hybrid of sorts.
In fact, I even call a typical parallel first-order filter "Pseudo First-Order" because of this. Without a shunt element of some kind, the driver has so much influence on the response that it cannot be viewed as a purely first-order filter. But when the real impedance of the driver is considered, a circuit can be designed that provides exactly the response needed. The "Psuedo First-Order" circuit may be just what is wanted. Or some other configuration might be more in line with what is needed.
I find one interesting feature of the series first-order crossover is its tolerance for impdedance shift. But since (series or parallel) first-order filters pass so much out of band energy, I don't recommend them for ribbon or compression horn tweeters. The tweeter is presented more back-EMF from the woofer in the series configuration too, making them even more fatal for frequency sensitive tweeters. But for low-power systems, it is an interesting configuration that has some benefits.
In a sense, a crossover isn't really series or parallel or Butterworth or Linkwitz-Riley unless the load is purely resistive. Since it isn't, the best crossovers are usually combinations of filters, having dampers and other mechanisms to provide the transfer function desired. I think the labels we put on certain configurations are somewhat misleading, since it implies a certain behavior that really isn't there. It would be with a purely resistive load, so the labels are useful for identification, but I think it is often overlooked that each circuit performs much differently than expected when reactive and non-linear loads are presented, such as is the case with loudspeakers.
Previous Topic: lothx, cain or king?
Next Topic: FINISHED basshorn plans!
Current Time: Fri Oct 16 01:37:27 CDT 2026
