Home » Audio » Speaker » My 30hz basshorn with 2226h
Options [message #16349 is a reply to message #16334] Sun, 11 April 2004 07:16 Go to previous messageGo to previous message
Its nice to know its possible,and do-able! Im amazed the small mouth works so well in a corner.
someday il get SW and mic and measure the distortion ,see what i get. i think that the wm-60 will provide something of a measurement anyway.
WHen i have a measurement system setup,il have a fit of measurements-tv speaker,pc speakers,car,home,jbl 15",digitor horn :p
What il do-see about a flat first! -i may not have room for a corner horn if my room is 2x4m :-) then i may only have room for a 12" in 3cubes :-S
then make a choice after that :-)
Cheers!
Previous Topic: Subwoofer Horn
Next Topic: Double-Blind test proves conclusively Fostex 103E is a horrible liddle squawker!
Current Time: Sat Nov 07 07:19:40 CST 2026
