Home » Audio » Speaker » sensitivity question
It's probably a midrange thing. [message #16313 is a reply to message #16308] Fri, 09 April 2004 06:13 Go to previous messageGo to previous message
Sensitivity isn't always measured the same way; a lot of driver manufacturers average it over the bandwidth, while some measure at 1kHz. In this case I'd say that the EVs probably are putting out a stronger midrange than the other(500 to 1.5kHz), which will subjectively sound louder due to the stepped sensitivity of the ear (see Fletcher-Munson curves)than lower and higher frequencies at the same or even somewhat higher SPLs. You can check it easily enough via an RTA or swept sine SPL measurement.
Previous Topic: More spectacular Horns
Next Topic: Opinions - Eminence Deltalite 10 and 12
Current Time: Tue Nov 03 06:14:04 CST 2026
