Home » Audio » Speaker » What is the throat dimension of the Altec A7 horn?
What is the throat dimension of the Altec A7 horn? [message #16243] Sat, 20 March 2004 13:15 Go to previous message
I'm wondering how to interpret the concept of throat dimension with respect to designs like the Altec A7 (828 cabinet).
The baffle has an 8 X 13 inch opening in it. But on the front side of the baffle the horn opens up to approximately 8 X 17 inches. There's no transition.
Is there an inherent problem with this? Would it be better if the top and bottom surfaces were angled so that the horn section began with an 8 X 13 inch section?
Thanks
Previous Topic: Suppose you had a really big pair...
Next Topic: Another approach to PVC design
Current Time: Fri Oct 16 19:17:29 CDT 2026
