Home » Audio » Speaker » basshorns ctd
I think the labhorn is pretty impressive already [message #16235 is a reply to message #16234] Mon, 15 March 2004 18:00 Go to previous message
So you want 20hz for a PRO unit event/ you wont get high efficiency from a DOORway movable horn.
perhaps 100db/1watt only ...
Id use the lab12 because its such high xmax,with LF youd need the excursion.
The question is,do you need it,really i think a labhorn or similar will suit the task just as well. 30hz clean is very impressive on its own
Cheers!
Previous Topic: Amps for Maggies
Next Topic: Hospital 2Pi's
Current Time: Fri Nov 13 06:49:59 CST 2026
