Home » Audio » Speaker » Why Flares?
Why Flares? [message #16208] Mon, 08 March 2004 21:27 Go to previous message
Straighten me out if I'm wrong. My understanding is that the horn in front of a compression driver acts as a transformer, to allow for a better impedence match between the diaphram and the air in the room. The end result is increased sensitivity.
What I don't understand is, most compression drivers with horn flares are typically 10dB to 15dB more sensitive than the cone drivers in the same speaker. Why attach the flare to increase SPL, and then attenuate it with an L-pad? Can't compression drivers be used without flares, and therefore, operate at (almost) the same sensitivity level as the woofers?
Gar.
Previous Topic: Tannoy info
Next Topic: A few questions
Current Time: Mon Oct 12 16:53:12 CDT 2026
