Home » Audio » Speaker » series, parallel and speaker sensitivity
Re: series, parallel and speaker sensitivity [message #16165 is a reply to message #16164] Sat, 21 February 2004 16:34 Go to previous messageGo to previous message
Parallel connections increase current flow if voltage is held constant. Series connections reduce current and increase maximum safe voltage. Two speakers connected in parallel will be louder with the same voltage input. Connected in series, they will handle higher voltage.
If you want higher sensitivity and don't need higher power handling, go with a parallel connection. If you don't need higher sensitivity but do need a higher maximum SPL, go with the series connection. Either way, you'll want to make sure you're staying within the operating range of your amp.
Previous Topic: Cool article on TNT-audio by a single driver nut...Thanx Martin!
Next Topic: Deal sheet from Parts Express... Goldwood 8"
Current Time: Wed Nov 18 16:15:02 CST 2026
