Home » Audio » Speaker » Questions about piezo super tweet
Re: Questions about piezo super tweet [message #16111 is a reply to message #16110] Sun, 08 February 2004 14:48 Go to previous messageGo to previous message
To attenuate the tweeters without forming a crossover, put a capacitor in series with them. If you want a resistor in shunt for amp-load purposes, then put it ahead of the capacitor. Placing a resistor directly across the tweeter connector lugs when using a series capacitor forms a first-order crossover. If you want a crossover for the tweeters, then that may be appropriate and there are many other suitable circuits too. But if you want to run 'em "crossoverless" - with mechanical rolloff at 3500Hz - then remove the shunt resistor or place it ahead of the series attenuation cap.
Previous Topic: 30hz horn design complete.
Next Topic: Adjusting for difference in gain in biamping
Current Time: Fri Nov 06 00:52:28 CST 2026
