Home » Audio » Speaker » 18" Subwoofer Horn - Opinions wanted!
Re: DD2012 pic! big rip :( [message #16087 is a reply to message #16085] Tue, 27 January 2004 19:04 Go to previous messageGo to previous message
Hi Mike,
You can make a patch to to the cone using a thin glue and a layer of fiberglass mesh tape similar to a drywall joint tape. An epoxy as Bill suggest and a small patch on either side would be best. Try to keep the patch small because you dont want a weight build up that will change your drivers specs. Anything you do to repair it will of course change the sound. The question is can you hear the change or is it worth a recone. If you have a 1/2 hour it's worth a try.
Bill
Previous Topic: Woofer tear-what to do
Next Topic: Paudio large woofers..
Current Time: Fri Nov 06 07:16:46 CST 2026
